2000 Dodge Durango 5.9 will not start 150k
Old Sep 29, 2011 | 07:26 PM
GregS1's Avatar
GregS1
Default 2000 Dodge Durango 5.9 will not start 150k
I have a dodge Durango that my daughter is driving now....I have owned it since new. Its been a great vehicle. It will not start....I got it to start...then it was running and missing at around 3500 rpm...very wierd. Turned it off...now it will not start.
I replaced the plugs, wires and cap and rotar around 10k miles ago.
The engine is showing in the dash.....any ideas.
Old Sep 29, 2011 | 09:53 PM
hydrashocker's Avatar
hydrashocker
Get the codes from the check engine light. Then post up the codes here and we can assist you. They will be in P**** format (example p0341). Turn the key back and forth rather quickly.
2000 and newer directions:
Turn the key to ON (not start), OFF, ON, OFF, ON and leave it there. If you look in the odometer window the codes will flash any code(s) with a small delay between each result. Each code should be in a P#### format, and will say PDONE when completed - turn your key to OFF and remove. Use the OBD code list to determine what problem the computer detected.
Old Sep 29, 2011 | 10:41 PM
IndyDurango's Avatar
IndyDurango
With nothing else to go on...
Coil first.
CPS second.
Fuel pump third.
IndyD
