Solution for a lift?>
Old Oct 2, 2011 | 12:34 PM
fielder87's Avatar
fielder87
Default Solution for a lift?>
Hey all.So I have a 00 durango,4x4 4.7l V8 blue,leather.I want more clearance.I read 33s will fit with soime rub?Also i cant find any lift kits available...I was wondering if a ram truck lift kit will fit up,since they had the same frames then?...will torsion and shakles w/ body lift be good enough?Thanks kyle
Old Oct 2, 2011 | 03:38 PM
adukart's Avatar
adukart
The ram frame is completely different from the durango. To fit 33's it is best to do the body lift but if you don't off-road you may be able to get away with just the t/s lift.
Old Oct 2, 2011 | 09:23 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the ram does NOT have the same frame as the durango, that would be the dakota
Old Oct 3, 2011 | 04:06 PM
fielder87's Avatar
fielder87
Well that sucks.I test drove new 2011 turbo diesel truck and the guy told me they had same frame that year.lmfao...anywho i do off road and climb hills, so i would want the body lift for more clearence...also i sen a lift for a 99 durango will that bolt up?thanks kyle
Old Oct 3, 2011 | 04:22 PM
adukart's Avatar
adukart
Don't know if that lift will work but it should. You will have a much stronger setup to if you do a t/s and body lift. That will give you 5in of lift safely, if you modify the bumpers and possibly fenders you can fit 35's
Old Oct 3, 2011 | 06:03 PM
hydrashocker's Avatar
hydrashocker
Well that guy didn't know his *** from a hole in the ground!
First of all, to hold just the 6.7L motor (1,050 lbs dry weight) up a Ram has to have a 3/4 ton front end.
Old Oct 3, 2011 | 07:19 PM
fielder87's Avatar
fielder87
ok. thanks for the help all
Old Oct 3, 2011 | 07:20 PM
lvphotos's Avatar
lvphotos
33s rub with the torsions cranked, worse with offset rims. Check my cardomain page under lvphotos. Stock with 31s,33s,lift with 33s and 35s full stuff with and without 5.5" Tough Country lift. 98/99 had steering box yours has rack. Wish I would had done the solid axle swap. I went the fiberglass fender route after getting hit in the nose.
Old Oct 3, 2011 | 07:24 PM
fielder87's Avatar
fielder87
o ya eh..I can avoid the rubbing, to have satisfation of 33 12.5/15 ..i'll deff check out man thanks
Old Oct 3, 2011 | 09:53 PM
srch4me's Avatar
srch4me
fiberglass fenders...
http://www.glassworksunlimited.com/19to20dodafr.html
