wiper fluid
Old Oct 8, 2011 | 12:07 AM
laz45's Avatar
laz45
Yeah the Rain-X works good I juz don't like the orange stains after....I'll give the Purple Power a try and see how it does......around here we add half a bottle of 70 percent alcohol to what ever is in the res....usually keeps it from freezing unless it's really bad out....
Old Oct 8, 2011 | 01:47 PM
hydrashocker's Avatar
hydrashocker
I knew a buddy that used to do that and never had a problem. I on the other hand thought that would dry out the plunger on the pump motor and render it useless? But you are saying it works huh?
Old Oct 10, 2011 | 07:01 AM
laz45's Avatar
laz45
I do it if I'm stuck buying the cheap stuff. That crap freezes right up and makes things worse here on the coast.....yeah it works. I was nervous about it drying out the pump seals and plunger also but it hasn't happened yet, Doesn't mean I haven't shortened it's life though.....It's like some old trick I heard about years ago,like I said though,I only do it if I'm not at a store that sells better fluid....
Old Oct 27, 2011 | 01:10 AM
otgarzā's Avatar
otgarzā
After reading the responses i too bought some of that purple power stuff..it was $3.50 a bottle at a local gas station. I also got one of my buddies trying the prestone stuff...well see what works better this winter :-)
Old Nov 5, 2011 | 10:34 PM
otgarzā's Avatar
otgarzā
That stuff was on sale $1.87 a gallon so i said might as well buy 12 since it was the limit. I like the stuff so far...
Old Nov 5, 2011 | 11:45 PM
Radar696's Avatar
Radar696
I like the Rain-X.
I hardly ever need to use my wipers when it's raining.
I might look at the stuff at Menards though if it's good to -35.
Living in Michigan no matter what you do you still have days when it freezes in the line and won't spray the window.
