Front End.
Old Oct 8, 2011 | 11:34 AM
justin101's Avatar
justin101
Default Front End.
My Durango's front end doesn't feel as "tight" as it should be. Now I put brand new shocks all the way around about 500 miles ago and the recalls have been done such as the ball joints. Every time I hit a bump or pot holes with one of my front tires it feels like everything is wobbling. I was just wonder if there was anyway to tighten things up.
Old Oct 8, 2011 | 03:24 PM
hydrashocker's Avatar
hydrashocker
Could be sway bar bushings or tie rod ends. Do you have tire wear?
Old Oct 8, 2011 | 09:16 PM
justin101's Avatar
justin101
No the tires have 500 miles on them as well. Got them the same time as shocks.
Old Oct 9, 2011 | 01:31 PM
hydrashocker
First look under the front end on each side and see if the bump stops are touching the control arms, if you you need to adjust the front end height. If not then it is most likely you sway bar bushings are worn out.
Have you checked the front end out for any worn parts?
