Cant shift out of Park. 02 durango, 4.7L
I have an 02 Durango wih a 4.7L, 105K miles that has been dependable and properly serviced, even the tranny.
I can no longer shift the lever out of park to put it in any gear.
Is there a solenoid or electronic switch i should be looking for or is there something that might be jamed in the steering column.
I am a very good mechanic but where its parked right now i cant get it towed to my shop.
thank you in advance
Brian
Brian
glad you figured it out, and remember the search function on this forum is your friend (if that doesnt work try google with www.dodgeforum.com as the precurser to your search term and it will search the forum too), you would have found both your solution and the function of the brake light switch.
