45rfe question
Old Oct 14, 2011 | 11:27 AM
Blind Monkey's Avatar
Blind Monkey
Default 45rfe question
going to look at a 4.7 in a '00 grand cherokee, thats been in the front, for my '00 durango. if I bought the entire wrecked GC is the 45rfe in it same as for my durango?
Old Oct 14, 2011 | 03:34 PM
adukart's Avatar
adukart
Yes it should be the difference is the tcm. GC were programmed to utilize 5 speeds and the durango's only 4.
Old Oct 14, 2011 | 04:33 PM
MoparMan1991's Avatar
MoparMan1991
Yes, the ONLY difference is the TCM (Transmission Control Module). If you had a 2001 Durango you could do the 45RFE to 545RFE TCM swap and get a 5th gear.
Old Oct 15, 2011 | 02:19 AM
Blind Monkey
perfect. bought the engine and tranny before I had a chance to get back and read this. $300 for the engine, $100 for the tranny, cant go to wrong with that. approx 150,xxx km(90,xxxmiles). pulled the engine oil filler off to look inside before I bought it, CLEAN! no sludge, just nice and clean. wasn't able to run it before I bought it as the comp had been stolen from it along with other stuff but I did put a ratchet on the crank and turn the crank over 2 complete revolutions feeling for resistance other then compresion and it felt good. plan to pull the timing cover for tensioner/guide inspection and the oil pan to make sure nothing is in the oil pickup screen before I put it in my durango.
wish I had an '01, would like to get the 5spd tcm just to see what its like, from what ive read my driving habbits would not warrent having it unless I was making long trip.
Old Oct 15, 2011 | 03:59 AM
MoparMan1991
If you have a 98-00 it will work you will just have to deal with the gear selection indicator being all lit up and a potential CEL that pops on and goes away real fast every now and again.
