cold start
Old Oct 21, 2011 | 06:07 AM
4x4Dakota93's Avatar
4x4Dakota93
Default cold start
Like a cold start at idle it will die if I rev it up to about 5-6 grand then dive it while going to neutral then drive it will eventually act right but at idle still les than 1000 on my rpm
Old Oct 21, 2011 | 06:19 AM
01dango4x4's Avatar
01dango4x4
If its cold you don't need to be revving it to 5-6k anyways
Old Oct 21, 2011 | 07:11 AM
4x4Dakota93
Letme explain it better, when I start my durango, it goes straight to 1250 rpm or so for 2 secs then just drops and dies, only way to keep it running is to turn it on , put it in neutral and hold a high rev on motor, if I try to throw it into reverse or drive it will die instantly, if I keep playing with throttle holding high rev, after bout 5 mins to 10 mins it will finnaly hold an idle and I can drive, any ideas?
Old Oct 21, 2011 | 07:50 AM
jetuco's Avatar
jetuco
I had the same issue, with my 99SLT 5.9L . Changed the IAC and cleaned out the port this corrected the issue. Engine starts up now immediately and holds idle no prob. ...... Oddly though i still have the issue like "noise_maker", where my engine will idle fine now at start, then begin to stumble for 2-3 min then smooth it self out and run fine.
Old Oct 21, 2011 | 07:57 AM
jetuco's Avatar
jetuco
sorry i meant the same problem as "dctaz37" not noisemakers prob. (noisemakers also sounds like the IAC.)
Old Oct 22, 2011 | 10:34 PM
hydrashocker's Avatar
hydrashocker
IAC or simply clean the IAC port and Throttle Body for that matter, and reset the PCM. If that doesn't help replace the TPS.
