1999 power steering question
Old Oct 26, 2011 | 12:43 PM
mrbassman26's Avatar
mrbassman26
Default 1999 power steering question
just replaced the steering gearbox on my 99 durango and it came with 2 o-rings. it says to use the o-ring on the pressure hose but i dont know which hose that is, plus, i dont remember which hose goes to which port on the gearbox, but they appear to be diff sizes so can only go in one port. is that correct? where can i find a ps diagram for this truck and which hose gets the o-ring? thanks
Old Oct 26, 2011 | 12:49 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
there is a 98durango FSM in the FAQ thread link i would download that and look under steering for the answer.
check here http://www.mediafire.com/?53f6w4a6wme00
Old Oct 26, 2011 | 01:05 PM
mrbassman26
perfect!! thank you!
Old Oct 26, 2011 | 01:22 PM
mrbassman26
it doesnt really say which hose is pressure and which is return?
Old Oct 26, 2011 | 07:32 PM
hydrashocker's Avatar
hydrashocker
I think the smaller hose is the pressure line. Just pull the coil wire and put the hoses in a bucket and have someone turn it over The pressure line will flow. Besides, you want to change out all the fluid anyway.
Then go to your dealer with you VIN# and get the correct fluid to go back in it. I think yours should be a special Brown fluid but only a dealer can tell you for sure.
