HELP I cant see....
Old Oct 28, 2011 | 10:43 PM
thenyscrod's Avatar
thenyscrod
Default HELP I cant see....
I have an 03' Durango.
Yesterday my wipers stopped in mid swipe.
I replaced the fuse 3 times in order to get home.
Motor overdraw ???
Short in wires ????
Any Help plz....
We are exspecting snow !!!!
Old Oct 29, 2011 | 01:03 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
ill move it for you this time, but it sounds to me like you have a short in the system, or a bad seal int he wiring somehow, time to start tracing wires and see if you can find a short. (it could be internal to the wiper motor if its intermittent)
Old Oct 29, 2011 | 03:18 PM
hydrashocker's Avatar
hydrashocker
Well I would test for a short to ground on each wire, R&R short.
If no short then the motor sounds like it is pulling to many amps, replace motor.
Old Oct 29, 2011 | 06:08 PM
master tech's Avatar
master tech
Site Moderator & Tech
Check with your dealer, because this may fall under this recall.
July 2004
Dealer Service Instructions for:
Safety Recall D22 – Windshield Wiper Motor
2002-2004 (AN) Dodge Dakota
NOTE: This recall applies only to the above vehicles built from April 24,
2002 through September 15, 2003 (MDH 0424XX through 0915XX).
2002-2003 (DN) Dodge Durango
NOTE: This recall applies only to the above vehicles built after
April 24, 2002 (MDH 0424XX).
IMPORTANT: Vehicles that have already had the proper wiper module
installed, according to warranty records, have been excluded from this recall.
In addition, 2000 through early-2002 model year vehicles (built through April 23,
2002 (MDH 0423XX)) that have had a suspect replacement wiper module
installed, according to warranty records, have been added to this recall.
Dealers are also requested to review their records and contact owners who have
purchased a wiper module or who have had a wiper module installed outside of
the warranty provisions (P/N 55154863AF or 55154863AG).
Water may enter into the windshield wiper motor on about 310,000 of the above
vehicles and cause the windshield wiper system to become inoperative. This can
impair the driver’s vision and cause a crash without warning.
The windshield wiper module must be replaced on all involved vehicles.
Models
IMPORTANT: Some of the involved vehicles may be in dealer new vehicle
inventory. Federal law requires you to stop sale and complete this recall
service on these vehicles before retail delivery. Dealers should also consider this
requirement to apply to used vehicle inventory and should perform this recall on
vehicles in for service. Involved vehicles can be determined by using the VIP
inquiry process.
Subject
Repair
Safety Recall D22 – Windshield Wiper Motor Page 2
Part Number Description
CBTBD220 Windshield Wiper Module
Each dealer to whom vehicles in the recall were invoiced will receive enough
windshield wiper modules to service about 5% of those vehicles.
1. Open the hood.
2. Remove the wiper arm plastic
nut caps and then remove the left
and right wiper arms.
3. Remove the cowl weatherstrip.
4. Remove the six (6) cowl grille
plastic nuts and two (2) cowl
grille push pins (Figure 1).
5. Disconnect the windshield
washer hose and vacuum reservoir
hose from the cowl grille.
6. Remove the cowl grille and set it
aside (Figure 1).
7. Remove the four (4) wiper module
screws (Figure 2).
8. Disconnect the wiper motor electrical
connector (Figure 2).
9. Remove the wiper module and
discard it.
10. Install the new wiper module into the
vehicle.
Parts Information
Service Procedure
Figure 1
Figure 2
COWL
GRILLE
PLASTIC
NUTS
PUSH
PINS
WIPER
MODULE
SCREWS
WIPER MOTOR
ELECTRICAL
CONNECTOR
WIPER
MODULE
Safety Recall D22 – Windshield Wiper Motor Page 3
11. Connect the wiper motor electrical connector (Figure 2).
12. Install the wiper module screws (Figure 2). Tighten the screws to 72 in-lbs
(8 N·m).
13. Install the cowl grille (Figure 1).
14. Connect the windshield washer hose and vacuum reservoir hose to the cowl
grille.
15. Secure the cowl grille with the six (6) plastic nuts and two (2) push pins
(Figure 1).
16. Install the cowl weatherstrip.
17. Install the wiper arms. Tighten the wiper arm nuts to 18 ft-lbs (24 N·m) and
then install the plastic nut caps.
NOTE: Ensure that the wiper arms are installed on the proper side of the
vehicle. The arms are marked DS (driver side) and PS (passenger side) on
the back of the arm. Be sure to align the wiper arms with the marks on
the windshield.
18. Close the hood.
19. Activate the windshield washer system to ensure it functions properly. Cycle
the wipers through all speeds, check the wipe pattern and adjust the wiper
position(s) if necessary.
Service Procedure (Continued)
Safety Recall D22 – Windshield Wiper Motor Page 4
Claims for vehicles that have been serviced must be submitted on the
DealerCONNECT Claim Entry Screen located on the Service tab. Claims
submitted will be used by DaimlerChrysler to record recall service completions
and provide dealer payments.
Use the following labor operation number and time allowance:
Labor Operation Time
Number Allowance
Replace the windshield wiper module.
Add the cost of the recall parts package plus applicable dealer allowance to your
claim.
NOTE: See the Warranty Administration Manual, Recall Claim Processing
Section, for complete recall claim processing instructions.
Not required.
All dealers will receive a copy of this dealer recall notification letter by DMAIL
and by first class mail. Two additional copies will be sent through the DCMMS.
DealerCONNECT will be updated to include this recall in the near future.
Completion Reporting and Reimbursement
Parts Return
Dealer Notification and Vehicle List
Safety Recall D22 – Windshield Wiper Motor Page 5
All involved vehicles have been entered into the DealerCONNECT Global Recall
System (GRS) and Vehicle Information Plus (VIP) for dealer inquiry as needed.
Involved dealers were also mailed a copy of their vehicle (VIN) list with the dealer
recall notification letter.
GRS provides involved dealers with an updated VIN list of their incomplete
vehicles. The owner’s name, address and phone number are listed if known.
Completed vehicles are removed from GRS within several days of repair claim
submission.
To use this system, click on the “Service” tab and then click on “Global Recall
System.” Your dealer’s VIN list for each recall displayed can be sorted by: those
vehicles that were unsold at recall launch, those with a phone number, city, zip
code, or VIN sequence.
Dealers must perform this repair on all unsold vehicles before retail delivery.
Dealers should also use the VIN list to follow up with all owners to schedule
appointments for this repair.
Recall VIN lists may contain confidential, restricted owner name and address information that
was obtained from the Department of Motor Vehicles of various states. Use of this information
is permitted for this recall only and is strictly prohibited from all other use.
All involved vehicle owners known to DaimlerChrysler are being notified of the
service requirement by first class mail. They are requested to schedule an
appointment for this service with their dealer. A generic copy of the owner letter is
attached.
Enclosed with each owner letter is an Owner Notification postcard to allow owners
to update our records if applicable.
Dealers are encouraged to consider alternative scheduling and servicing
approaches for this recall. This repair does not require hoists or other full service
facility special equipment and is a DaimlerChrysler Mobile Service approved
repair.
Vehicle Lists, Global Recall System, VIP and Dealer Follow up
Owner Notification and Service Scheduling
Safety Recall D22 – Windshield Wiper Motor Page 6
If you have any questions or need assistance in completing this action, please
contact your Service and Parts District Manager.
Customer Services Field Operations
DaimlerChrysler Corporation
Additional Information
SAFETY RECALL – WINDSHIELD WIPER MOTOR
Dear: (Name)
This notice is sent to you in accordance with the requirements of the National Traffic and Motor Vehicle Safety Act.
DaimlerChrysler Corporation has decided that a defect, which relates to motor vehicle safety, exists in
some late-2002 through 2004 model year Dodge Dakota trucks and late-2002 and 2003 model year
Dodge Durango vehicles. In addition, this recall also involves a small number of 2000 through
early-2002 model year Dakota and Durango vehicles that had a service replacement windshield wiper
motor installed.
The problem is... Water may enter into the windshield wiper motor on your Dakota or Durango
(VIN: xxxxxxxxxxxxxxxxx) and cause the windshield wiper system to become
inoperative. This can impair the driver’s vision and cause a crash without
warning.
What your dealer
will do...
DaimlerChrysler will repair your vehicle free of charge (parts and labor). To
do this, your dealer will replace the windshield wiper motor assembly. The work
will take about ½ hour to complete. However, additional time may be necessary
depending on how dealer appointments are scheduled and processed.
What you must
do to ensure your
safety...
Simply contact your dealer right away to schedule a service appointment. Ask the
dealer to hold the part for your vehicle or to order it before your appointment.
Remember to bring this letter with you to your dealer.
If you need
help...
If you have questions or concerns which your dealer is unable to resolve, please
contact DaimlerChrysler at 1-800-853-1403.
Please help us update our records, by filling out the enclosed prepaid postcard, if any of the conditions
listed on the card apply to you or your vehicle. Be sure to print the last eight (8) characters of the VIN
(VVVVVVVV) and notification code D22 on the postcard.
If you have already experienced a wiper motor failure and have paid to have it repaired, you may send
your original receipts and/or other adequate proof of payment to the following address for reimbursement:
DaimlerChrysler, P.O. Box 610207, Port Huron, MI 48061-0207, Attention: Reimbursement.
If your dealer fails or is unable to remedy this defect without charge and within a reasonable time, you
may submit a written complaint to the Administrator, National Highway Traffic Safety Administration,
400 Seventh Street, S.W., Washington, DC 20590, or call the toll-free Auto Safety Hotline at
1-888-327-4236.
We're sorry for any inconvenience, but we are sincerely concerned about your safety. Thank you for your
attention to this important matter.
D22
Note to lessors receiving this recall: Federal regulation requires that you forward this recall notice to the lessee within 10 days.
Old Oct 30, 2011 | 03:16 AM
maxfly's Avatar
maxfly
good call MT. i got the build sheet for mine a few months ago and it said that i needed to have mine looked at because of that recall. i hadnt taken it seriously until now. ill be heading to the dealership monday. @OP be sure to let us know if they cover yours under the recall. ill repost once i find out what they do to mine.
