misfire and oil consumption
Old Nov 1, 2011 | 10:57 AM
skj1822's Avatar
skj1822
Default misfire and oil consumption
high i have a 98 d with a 5.2 getting multiple missfires on 158 and cam/crank sensor code also lots of oil consumtion havent noticed any smoke or leaks well a little on start up for like the first 2 sec and not alot either but im not behind it goin down the road new plugs havent changed the wires yet everything was fine the other day then bam ligh comes on so i was wonderin wires or cam sensor or is it the crank and what of the oil use belly pan maybe>also has been backfiring trough the intake still has power when its not missing
Old Nov 1, 2011 | 05:57 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
Old Nov 5, 2011 | 02:58 PM
whollysheet's Avatar
whollysheet
it will be your intake causing the oil consumption which will also case your plugs to foul! Under the intake is a steel plate with a weak gasket that blows out! On ebay you can order an aluminum plate for $50.00 Delivered to your door and from your auto parts store get the gaskets! replace them and you oil consumption will disappear and you will have alot more power!
Old Nov 5, 2011 | 08:55 PM
mvoss2576's Avatar
mvoss2576
+1 on the intake, that was what was wrong with mine. About 2" of the gasket was missing.
