Power window issues
Old Nov 3, 2011 | 05:56 PM
kmalo86's Avatar
kmalo86
Default Power window issues
hey guys need some help here the passenger window on my 01 durango keeps dropping for no reason motor runs but wont lift or drop window itself any ideas on whats going on here would be greatly appreciated
Old Nov 3, 2011 | 10:50 PM
IndyDurango's Avatar
IndyDurango
broken cable most likely.
Old Nov 3, 2011 | 10:55 PM
adukart's Avatar
adukart
+1 indy, that is quite common.
Old Nov 3, 2011 | 10:58 PM
TurboStixx's Avatar
TurboStixx
Cable broken on Window Regulator? Had the exact thing wrong with my Civic, could hear the motor running, but the window wouldn't move. Just repalced the regulator and VIOLA! Fixed, atleast yours goes down, My passenger side windows just don't go down lol
Old Nov 3, 2011 | 11:30 PM
brhodes's Avatar
brhodes
Yep, almost certainly a cable. This is something I'm pretty familiar with. I pulled the passenger regulator out to see why the window wouldn't move, turned out the cable was balled up inside the pully case. I tore it all apart, cleaned it up and got new cables and put it all together but I'm having a hard time getting cable stops that will hold. After running it up and down for a few minutes to test it thoroughly, the stops pull off the end of the cable. I don't have a swaging tool (using a crimper), and I can't seem to get it to work well. I've thought about solder, but it's hard to get solder to stick to galvanized wire, apparently.
Anyway, Kmalo...these guys are 100% right, broken cable (or cable stop pulled off end of cable). You can either buy a new regulator ($60 and up), or elect to be a cheapskate (and a master DIY guy ) like me and repair it yourself, spending a few bucks on cable, and a few days trying to figure out how to make the cable stops stay on the end of the cable.
Old Nov 4, 2011 | 08:31 PM
kmalo86's Avatar
kmalo86
thanks everyone i have located a new regulator for 28$ on partstrain.com so im just going to replace i appreciate all the help was not looking forward to having to send it to a shop for something stupid like that thanks again
