durango radiator help
Old Nov 5, 2011 | 02:30 PM
hydrashocker's Avatar
hydrashocker
Originally Posted by Justin6
its got a cooler on it. two bolts mount it to the radiator in between the condensing coil and the radiator. the lines come around the radiator and screw into the radiator. I'm not sure if its the tow package or not.
You have the tow package. Get the one that has the transmission cooler on it already. This should be the more expensive one. It will be plug and play and will be OEM.
