Cooling fan
Old Nov 15, 2011 | 05:13 PM
noman's Avatar
noman
Default Cooling fan
Is there a way to remove the cooling fan without getting that special tool
the book say you need?
Old Nov 15, 2011 | 05:16 PM
IndyDurango's Avatar
IndyDurango
Brace the fan and hammer the nut. That is what I did. No special tool was ultimately required.
IndyD
Old Nov 15, 2011 | 06:30 PM
noman's Avatar
noman
It didn't sound like it was a special tool. Just something to hold the fan from turning. Shouldn't be that bad I don't think.
Old Nov 15, 2011 | 07:06 PM
brhodes's Avatar
brhodes
Use a wooden wedge to hold the pulley if you have to, and do like he said...whack it once or twice with a hammer, and then use a big wrench (or channel locks, or whatever) and it'll come off pretty easy.
Old Nov 15, 2011 | 07:31 PM
that_guy's Avatar
that_guy
this should give you all the info you need
https://dodgeforum.com/forum/1st-gen...n-fan-nut.html
Old Nov 15, 2011 | 08:02 PM
noman's Avatar
noman
I thought I just saw something about removing the fan. I went and tried searching for it and couldn't find anything. Thanks for the help
Old Nov 15, 2011 | 08:21 PM
that_guy's Avatar
that_guy
no problem. That nut removes the clutch and fan. Once you get the fan and clutch off it is very easy to get the fan off the clutch, just 4 bolts
