weird noise from drivers side door
Old Nov 22, 2011 | 06:41 PM
turbo2point4's Avatar
turbo2point4
Default weird noise from drivers side door
when unlocking the doors with the fob, or unlocking using the switch in the door you can hear a noise, but it doesn't do it when locking, i was wondering if anybody has had this happen and what the fix was or if theres some sort of an adjustment for the motor/actuator that unlocks the driver side door, it almost sounds like its trying to push the lock further and causes the motor/actuator to make a buzzing noise, thats assuming thats the problem the motor/actuator, but i'm not sure what else it could be really, since theres not much to the power lock system in the door.
Old Nov 22, 2011 | 07:27 PM
dolittle's Avatar
dolittle
turbo replace the door latch inside the door. My right rear door started to make a buzzing sound when unlocking now the door will not unlock at all and if you can't open it you will not be able to replace the latch. The latch has some plastic parts and I think one in mine has broken. So I suggest getting a new one soon. The motor/actuator is in the latch.
Good luck with this.
Old Nov 24, 2011 | 07:15 AM
turbo2point4
alright thanks, i called the dealer about it, the latch is $129.00 and its a special order part of course lol
Old Nov 29, 2011 | 01:39 PM
turbo2point4
picked up the latch today, and put it in... wasn't too bad worst part was getting the 2 rods on the back side of the latch, more so the one that has the yellow lock on it, the red one wasn't too bad.... thanks again
Old Nov 29, 2011 | 01:41 PM
TurboStixx's Avatar
TurboStixx
did it fix the issue?
Old Nov 29, 2011 | 02:06 PM
turbo2point4
yes it did, no more buzzing noise.
Old Nov 29, 2011 | 02:15 PM
TurboStixx's Avatar
TurboStixx
awesome, glad you fixed it.
Old Nov 29, 2011 | 02:25 PM
turbo2point4
thanks
