Evap Leak hose kit P0455
Old Nov 25, 2011 | 07:24 PM
iwork4911's Avatar
iwork4911
Default Evap Leak hose kit P0455
Maybe I am just really late on this one, but I FINALLY got around to replacing my evap hoses for the fuel vapor return.
I was at the parts store about to purchase a length of hose off their bulk spool to replace the curved ends that plug into the canister at the gas tank. The guy said they carry a repair kit with pre-cut, pre-formed, and flanged hoses just for my Durango. This kit saved me a bunch of money by not having to buy $6 foot hose, clamps, and a reducer because one of the hoses has different sized ends on it.
The kit is by Dorman, part # 46020. Rock Auto has this kit for $3.44
The kit has both the large hose and the small hose, you really can't beat the price. It says it is for Dodge Durango & Dakota, 2001-2004, and they fit on there perfectly. 5 minute job to swap out the cracked ones with new ones.
http://www.rockauto.com/dbphp/x,cata...MAN_46020.html
http://www.rockauto.com/catalog/moreinfo.php?pk=1027892
Old Nov 26, 2011 | 01:48 AM
IndyDurango's Avatar
IndyDurango
Nice post and info iwork4911. Thanks!
IndyDurango
Old Nov 28, 2011 | 02:15 PM
Bobman's Avatar
Bobman
Ordered and shipped.... great find! Thanks!
Hydra, maybe add this one to the DIY post?
Bob
Old Nov 28, 2011 | 10:15 PM
hydrashocker's Avatar
hydrashocker
I would if I could, but I am retired. Sharps can do it.
Old Nov 29, 2011 | 10:37 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i thought i had done it already tbh,
Old Dec 7, 2011 | 09:44 AM
soto26's Avatar
soto26
I was throwing a P0440, P0442 and P0456. I replaced the gas cap and now only throw 442 and 456. From what I could find it is just a small vapor leak and to test it i need some special tool to detect that kind of thing. I'm stationed in the UK and dont have access to any shops that know anything about american vehicles. Could it just be these two hoses? Could it really be that simple?
Old Dec 7, 2011 | 10:21 AM
shrpshtr325
THE ULTI-MOD
it is possible(very likely) that that these hoses will fix the issue
P0442 Evap Leak Monitor Medium Leak Detected
P0456 Evap Leak Monitor Small (0.020) Leak Detected
Old Dec 7, 2011 | 11:20 AM
Bobman's Avatar
Bobman
Crawl under your truck and look for a small black box just to the rear of the drivers seat. You'll see two hoses coming from it. Examine them closely for splits & cracks (they most likely are dried out at the ends). Repair & replace as needed. This kit is nice because the lines are different diameters at each end, so a normal piece of hose won't work without adaptors.
The other "hidden" place to look for a leak is a rubber line located under the battery tray. Someone here turned me on to that one, otherwise I would have never found it!
Bob
Old Dec 8, 2011 | 06:35 AM
soto26's Avatar
soto26
Thanks. I'll check when I get home. The hoses were so cheap from rockauto I just ordered them anyways without even inspecting it. Of the three common problems with 99 to 02 durangos I have them all. The evap problem, rear heater not working cause of the broken door and the resistor problem. I just bought the thing a couple months and only paid 4500 for it with 110K on it. I think I got a pretty good deal because these fixes are really simple and cheap.
Old Dec 26, 2011 | 04:34 PM
ccexpress's Avatar
ccexpress
Soto26, how do you fix the broken door for the rear heat? Please PM me since this post isn't about the door.
