Interchangeable parts
Old Nov 27, 2011 | 11:49 PM
Leaderda's Avatar
Leaderda
Default Interchangeable parts
I replaced my leaf springs on my 99 4x4 Durango with 2001 durango leaf springs, which fit perfectly and measured out same as old, but it now has a significant vibration above 25 mph! I also changed both rear drive u joints as rig has 166k. Any thoughts would be appreciated!
Old Nov 28, 2011 | 12:25 AM
that_guy's Avatar
that_guy
did you also replace the shocks
Old Nov 28, 2011 | 12:39 AM
logikfive's Avatar
logikfive
I'd double check your U-joints.
Old Nov 28, 2011 | 09:23 AM
ToastKing30's Avatar
ToastKing30
X2 on U-joints. Get under there and muscle the **** out of everything under there to check for looseness. Check all the bushings.
Old Nov 28, 2011 | 10:49 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
id lean toward the ujoint as the issue also, it is going to be a rotating part that is causing the vibration.
Old Nov 28, 2011 | 11:14 AM
Leaderda's Avatar
Leaderda
I changed u joints after vibration occurred. Yoke axle is good too. New shocks 3 months ago. Wondering about shackles! I lowered vehicle before tightening shackles, or should that have been done without vehicle weight ? Are the springs off 01 Durango a problem for 99?
Old Nov 28, 2011 | 12:26 PM
shrpshtr325
THE ULTI-MOD
the springs shouldnt be the problem
52106325AB SPRING, Rear Leaf, [ZAR,ZNR] from the 98 parts manual
52106830AH 4x4 SPRING, Rear Leaf from 2001 parts manual
52106831AH 4x2 SPRING, Rear Leaf from 2001 parts manual
honestly if they measured the same they should fit just fine and not cause any problems.
Old Nov 28, 2011 | 12:57 PM
that_guy's Avatar
that_guy
is it possible that you have a wheel out of balance
Old Nov 28, 2011 | 04:40 PM
Leaderda's Avatar
Leaderda
I actually supported vehicle with jack stands on axle and run in place with wheels on and off, and of course road test and get the same vibration. When installing springs I felt like the axle had to til forward 1/4" to set flat on spring, but u joint should accommodate something that minor. I also did rear drum cylinders at same time as leaf springs but double checked that as well. Everything was normal before spring change
Old Nov 28, 2011 | 04:45 PM
Leaderda's Avatar
Leaderda
Wheel balance ok, new tires. This vibration is significant.
