leaky D, have a look
Old Dec 1, 2011 | 08:47 PM
Ondelas's Avatar
Ondelas
Default leaky D, have a look
looking to identify what is leaking from these pictures its seems to be leaking right from that seal not from the oil pan or whatever in front of it and if anyone could give some advice that would be great to thanks
Attached Thumbnails leaky D, have a look-imag0527.jpg   leaky D, have a look-imag0528.jpg
Old Dec 1, 2011 | 09:25 PM
that_guy's Avatar
that_guy
hate to tell you, but it looks like one of the freeze plugs on the back of the block. I've had this happen before and you have to remove the transmission to get to it. PITA considering it's a 99cent part. About a grand in labor if you have someone do the work
Old Dec 1, 2011 | 09:26 PM
hydrashocker's Avatar
hydrashocker
Looks like coolant draining down the cab fire wall from the heater core connections.
If you have an inverted picture from the 2nd pic would confirm.
Old Dec 1, 2011 | 11:24 PM
IndyDurango's Avatar
IndyDurango
What is the fluid type?
IndyD
Old Dec 1, 2011 | 11:41 PM
ZCR1's Avatar
ZCR1
IndyD
+1, because if it is oil it could be a rear main seal.
Old Dec 2, 2011 | 12:01 AM
IndyDurango
if it is oil, agreed.
Old Dec 2, 2011 | 12:08 AM
bwdakrt's Avatar
bwdakrt
...or it could be a bad oil pressure switch at the back of the intake beside the dist?
Old Dec 2, 2011 | 01:33 AM
Ondelas's Avatar
Ondelas
it appears to be motor oil def not coolent thats all i know ;( ill try to get a few more pics
Old Dec 2, 2011 | 02:16 AM
IndyDurango
If it is trans fluid, there is a seal at the back of the transfer case that leaks and goes bad at around 9-10 years. That's my guess.
IndyDurango
Old Dec 2, 2011 | 02:41 AM
TurboStixx's Avatar
TurboStixx
If its oil then i am guessing rear main seal? Just a thought, guys, what do you all think?
