Crankshaft Pulley Seal
Old Dec 5, 2011 | 10:57 AM
DomsDodgeDingo's Avatar
DomsDodgeDingo
Default Crankshaft Pulley Seal
I have a really bad leak coming from what I believe to be the crankshaft pulley seal. Could someone tell me if this is something I could do myself and directions on how to do it? Thanks! Ps its a 2000 5.9 with 210k miles.
Old Dec 5, 2011 | 09:21 PM
hydrashocker's Avatar
hydrashocker
If you are talking about the front crank shaft seal then you need to first remove the vibration dampener (front pulley) with a remover, then remove the water pump, then the timing chain cover. This will get you to the seal.
Old Dec 6, 2011 | 07:21 AM
DomsDodgeDingo
Is it hard to do myself? Would I have to remove the radiator also?
