2001 Durango CTM replacement problem
Old Dec 5, 2011 | 12:06 PM
petermarcus's Avatar
petermarcus
Default 2001 Durango CTM replacement problem
I started having classic CTM problems on my '01 Durango -- locks opening and closing automatically, blinking headlights when wipers on, etc.
My old CTM was PN: 56045453AF
I got a new one from a salvage that was PN: 56045453AG
From what I've found on the internet, these are supposed to be compatible parts. I took out the old CTM, plugged in the new, and it immediately went into panic mode. I took the fuse for the horn out to spare my neighbors, but nothing I do seems to get it out of panic mode. Starting the car, closing the door, trying to program the keyless entry, it doesn't help.
Is this a common problem with a new CTM? Anyone know how to stop this from happening? One post said to try cutting the green/orange on PIN 14 on the central plug, but that didn't help (I've rewired it back in again).
Thanks
Old Dec 5, 2011 | 09:33 PM
hydrashocker's Avatar
hydrashocker
You need to get the new CTM flashed to your truck by the dealer. On thing you could try is to reset the alarm: https://dodgeforum.com/forum/1st-gen...going-off.html
Old Dec 5, 2011 | 10:50 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+1 hydra, CTM needs to be programmed by the dealer
also yes the parts are compatible, the AA (w/e the two digit alpha code on the end happens to be) just indicates part manufacturer
Old Dec 6, 2011 | 10:54 AM
petermarcus
The turning-the-lock thing didn't work, still in panic mode.
I thought the keyless thing had to be programmed by a dealer, but didn't know the CTM had to be, too. Guess I'll bring it in, then.
Thanks for the advice
