need help wit my 2000 dodge durango
I am fixing to replace the crank sensor on mine. take the fender lining out...it is a pain in the **** from the top, and the bottom. If it's not your crank sensor, next step is the coil. Then go to spark plugs, then cap and rotor. If you are getting crank, and no fire, I would think crank sensor first. If it's bad, it won't allow your coil to spark, and you may misdiagnose the problem and keep throwing money at it.
