Can you change your oil filter without draining your oil?
Old Dec 7, 2011 | 12:03 AM
Mechaniczman's Avatar
Mechaniczman
Default Can you change your oil filter without draining your oil?
I have a 1999 dodge durango 5.2L and i bought the wrong oil filter (stupid book at walmart) so i had to use my old one because i had already drained the old oil.
So can I just go buy a new filter and swap it out? I realize i will problably loose a little bit of oil by swapping the filter because oil comes out anyways when changing it but, thats better than buying another 5 quarts.
Thanks,
Mechaniczman
Old Dec 7, 2011 | 01:03 AM
IndyDurango's Avatar
IndyDurango
Yea, you can swap it. Should be just about as messy as normal. Remember to replace the oil lost during the swap AND the oil in the filter.
IndyD
Old Dec 7, 2011 | 09:13 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+1 indy
it can be done, id suggest doing it after the truck has sat for a while to minimize the mess (maybe in the morning) and make sure you top the oil off after you do it.
Old Dec 7, 2011 | 02:08 PM
Mechaniczman
tHank you so much now I can go buy a new oil filter and more oil I'm not too worrried about it because it already leaks and burns oil
