Code P300, P302
Old Dec 11, 2011 | 03:26 PM
quietdad's Avatar
quietdad
Default Code P300, P302
Hey I got an 2003 Durango with the 4.7 and an engine code of P300, P302 I replaced all the plugs and did some basic cleaning. If starts a little rough, and idles rough too til warmed up then runs great. I get around 15 mpg. I have already replaced the cam sensor last year. Any ideas please Thanks
Old Dec 11, 2011 | 05:08 PM
TurboStixx's Avatar
TurboStixx
Looks like you have a cylinder misfire on #2 from the codes, Did you replace the plugs with Champion Copper Plugs?
I had an issue where one of my O2 Sensors went bad, and actually threw these codes, of course my catalytic converter was bad as well.
Old Dec 12, 2011 | 11:02 AM
otgarzā's Avatar
otgarzā
Maybe the coil? or you used a different plug perhaps. Maybe a bad gasket somewhere in the intake...or a pcv hose.
Old Dec 12, 2011 | 10:32 PM
hydrashocker's Avatar
hydrashocker
P0300 Multiple Cylinder Misfire
P0302 Cylinder #2 Misfire
Get the regular cheap Champion Copper spark plugs and gap them to .040 and install. It also could be the crank sensor, but most likely it is the plugs.
