Crazy oil pressure!!! Help!!
Old Dec 13, 2011 | 12:42 PM
Dony409's Avatar
Dony409
Default Crazy oil pressure!!! Help!!
I have an 02 durango 4.7l it is fairly used (250,000km or 155,000 miles) when idling it has ok oil pressure for a high mileage vehicle. It is just above the second mark (\ l l /)
It's about ^ there!! When driving its
(\ l l /)
^ like there. I'm going to do an oil change right away (to check for sludge) how do I clean out the sludge if I got it?
Old Dec 13, 2011 | 03:33 PM
TurboStixx's Avatar
TurboStixx
I had an issue where my trucks Oil pressure gauge would drop to where yours is, when driving but usually when I came to a stop at like a traffic Light. I changed the oil and it stopped happening, I had no sludge(if you have maintained the vehicle I am guessing that you don't have sludge either) I would change the oil and make sure you put the right amount of oil in it. If that doesn't work I am guessing maybe oil pump or oil sending unit.
Old Dec 13, 2011 | 04:46 PM
that_guy's Avatar
that_guy
definitely try changing the oil first and see if that helps. Do the easy things first.
also, it is normal for the oil pressure to fluctuate some. As long as the needle is within the two inner marks you should be fine.
Old Dec 13, 2011 | 05:16 PM
adukart's Avatar
adukart
So lets get this straight. You are having normal oil pressure at idle and it is bottoming out when you start driving?
Old Dec 13, 2011 | 05:53 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+1 that_guy
also, you cannot accurately diagnose sludge without pulling the engine apart (usually the valve covers off)
Old Dec 13, 2011 | 09:58 PM
hydrashocker's Avatar
hydrashocker
That was the first thing that came to my mind as well!......Doesn't make sense!
I would suggest the oil is the wrong viscosity so replace it with 5W-30 or you could even try 10w-30 and a new Bosch filter. I would also replace the oil pressure sending sensor.
Old Dec 14, 2011 | 07:29 AM
Bobman's Avatar
Bobman
Could also be a cracked / clogged oil pickup. At low RPM's there's enough of a draw but when they go up the pump starts to cavitate because it's either drawing air (crack in the pickup above the oil level) or a clogged screen is restricting flow.
Get the oil & filter changed asap. If possible, put a temporary mechanical gauge in place of the sensor to check your real pressure.
Bob
Old Dec 14, 2011 | 06:35 PM
savwafare10's Avatar
savwafare10
Oil sending unit or glogged pick up screen
Old Dec 14, 2011 | 06:58 PM
Old_School's Avatar
Old_School
Had the same issue with my first car when i was 17...turns out that i was 4 quarts low!!!
Old Dec 14, 2011 | 07:27 PM
dsolorio's Avatar
dsolorio
I agree with Old_School I had a 89 Astro Van, it had damn near NO oil in it. The oil stick only had one single drop of oil at the tip of it. lol.
