Bull Bar Install
Old Dec 15, 2011 | 04:03 PM
08XDakota's Avatar
08XDakota
Exclamation Bull Bar Install
Hey guys me and my buddy are trying to figure out how to install a bull bar on his durango and cant figure it out......didnt come with instructions and cannot get in contact with the person i got it from. Any help would be greatly appreciated. Thanks
Old Dec 15, 2011 | 05:22 PM
adukart's Avatar
adukart
I do believe that you must cut holes in the plastic splash shield, then come up from the bottom in between the radiator and bumper to mount it to the frame. I believe you might have to undo the bumper bolts so you can use the same holes for the bull bar.
Old Dec 15, 2011 | 05:55 PM
HammerZ71's Avatar
HammerZ71
Every bull bar or grill guard I've ever installed mount to either tow hook holes (if so equipped) or the holes in the frame where the bumper mounts to it - usually using longer bolts...
Old Dec 15, 2011 | 06:49 PM
Duranged408's Avatar
Duranged408
http://westinautomotive.com/applicat...df/75-0431.pdf
Old Dec 15, 2011 | 07:05 PM
08XDakota's Avatar
08XDakota
Thanks guys for the responses, we got it on but yeah we came across the problem of how the bumper is in the way of having the bull bar sit perpendicular to the ground perfectly so were gonna have to cut some
Old Dec 15, 2011 | 07:40 PM
HammerZ71's Avatar
HammerZ71
That's pretty common, right in the directions for installing my Warn grill guard they showed you had to cut two slots in the bumper...
Old Dec 15, 2011 | 08:04 PM
08XDakota's Avatar
08XDakota
Yea that's a little ridiculous, you think they would just make the brackets a liiiiiittle longer so you wouldn't run into this problem
Old Dec 16, 2011 | 09:19 AM
Andreas2k10's Avatar
Andreas2k10
Default Dude
I very much like how your Durango looks.
Thant's all I have to say about that.
Old Dec 21, 2011 | 05:55 PM
bobbyrod75's Avatar
bobbyrod75
Default bull bar
will the bull bar from a 2nd generation durango(04) fit a 3rd generation dakota(06)? will there be any modifications needed. thanks
Old Dec 21, 2011 | 07:43 PM
dakotaff's Avatar
dakotaff
Different part numbers, probably will not fit.
