Oxygen Sensors
Old Jan 1, 2012 | 09:59 AM
TurboStixx's Avatar
TurboStixx
I forgot to mention that, I lubed them up actually last night when i FINALLY put the door back together. Thanks shrp!
Cargod, try using PB Blaster on them and doing them while they are warm. If that doesn't work let us know!!
Old Jan 1, 2012 | 12:01 PM
DomsDodgeDingo's Avatar
DomsDodgeDingo
I tried everything! I have an o2 sensor socket that I used. I heated it up until it was red. The only thing I didn't use was PB blaster. I used this stuff called Deep Creep by Seafoam and smacked the crap outta it with a hammer. Now The bolt is stripped and I feel I have no other choice. Might just have to take it to my mechanic instead of messing with it anymore.
Old Jan 1, 2012 | 02:35 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
are the threads stripped, or the flats on the socket?if its the flats, a set of vice grips can usually be gotten tight enough to grab, and if its already stripped you cant make it any worse right?
