Help! Freaking out after using Seafoam!
Old Dec 27, 2011 | 09:06 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if the plus are fouled up badly enough new plugs will fix the problem, w/o seeing the plugs myself i couldnt say for sure, however now is as good a time as any for a full tune up if it hasnt been done recently (plugs, wires, cap, rotor, brass contacts of course) just to make sure you get everything back to where it belongs.
however higher octane gas to top it off wouldnt hurt anything either, how much gas was in the tank when you added the seafoam?
Old Dec 27, 2011 | 10:31 AM
DomsDodgeDingo's Avatar
DomsDodgeDingo
I had it 3/4 of the way full when I added
Old Dec 27, 2011 | 10:35 AM
DomsDodgeDingo
So today I'll get some spark plugs and O2 sensors from the dealer. I am just SO relieved it is not something major. Im sure this question has been asked b4 a million times but why we are on the subject...what Spark Plugs do you reccomend for the D Shrp?
Old Dec 27, 2011 | 10:37 AM
DomsDodgeDingo
Oh and one more thing=) Not that I don't trust you, but being the inquisitive person I am how would higher octane has stop the knock? Thx!!
Old Dec 27, 2011 | 10:46 AM
adukart's Avatar
adukart
Use the cheap champion copper plugs, that is the OEM. Higher octane will can with stand a higher temperature environment that the fuel is in before ignition. So any hot spots in the combustion chamber or piston won't ignite the fuel as easily. It also carries more energy in it. Knocking is caused when you have two ignition sources. They both ignite the fuel in different areas then the reaction collides. Since your spark plugs are weak the second source is getting a chance to ignite the fuel also. Hope this answers some questions.
Old Dec 27, 2011 | 10:49 AM
Compactc9's Avatar
Compactc9
Everyone here usually recommends the Champion copper plugs, so I'd go with those.
For the higher octane gas, if its knocking, sometimes that it caused when the gas ignites to soon, higher octane gas won't do that.
Editing, forget what I said about the sea foam and the gas...
Old Dec 27, 2011 | 11:17 AM
DomsDodgeDingo
Ok thanks for the replies! So one more dumb question... If I have 1/2 tank of 87octane is it ok of I mix it with a higher octane gas like 92? Or do I have to wait for the 87 octane has to be gone first? Or could I just buy a bottle of octane booster instead?
Old Dec 27, 2011 | 11:35 AM
that_guy's Avatar
that_guy
our computers are setup to run on 87 octane gas. The 5.2s and 5.9s have no knock sensors. Running higher octane gas isn't going to get you anything.
Old Dec 27, 2011 | 11:38 AM
TurboStixx's Avatar
TurboStixx
+1 Guy
Old Dec 27, 2011 | 01:32 PM
shrpshtr325
THE ULTI-MOD
higher octane wont gain you any power
however it will get rid of engine knock
dom: you can put the higher octane into the tank whenever, it will mix w/ what is in there and the octane rating of the tank will be somewhere in between the two, will still raise it some (i wouldnt put less than 1/2 a tank in it myself, but you can)
yes champion copper core plugs, make sure they are gapped to .040
