???? Check Gauges light ????
Ok what is it what problems could it bee. I have all my Gauges working and they all are still in the norm for my D. WTH is it I have NEVER seem a Check Gauges dummy light..
?????????????????????????????????????????????? Help
If i had a Manual I would read it but I can't
does it stay on?
usually when it blinks on it is the coolant temp getting high(and then coming back down), or the battery voltage getting low(or high) and then coming back in range. the last thing would be the oil pressure disappearing.
No i haven't how do you do that?
with the key in the LOCK position, hold the trip reset button down, while holding it down turn the key to the ON position
it should run the gauges through different locations and if there is a problem display any codes in the odometer window, watch carefully
