Fixed another thing on my D, time to fix the next
Old Dec 29, 2011 | 08:47 PM
TurboStixx's Avatar
TurboStixx
Default Fixed another thing on my D, time to fix the next
Ok, now that i have the D running right, the best I can until it gets warm again.
Anyways, the passenger side windows do not work. Neither of them do, but in different ways.
Rear Window: when the button is pressed down it goes down about a centimeter, but makes a kind of jammed motor sound, thinking regulator?
Front Window: Does nothing, no sound no movement....door lock button works....at a loss on this one....
Old Dec 29, 2011 | 09:04 PM
DomsDodgeDingo's Avatar
DomsDodgeDingo
The front window definately sounds like the motor. Same thing happened with my back window. Yeah I think regulator on your rear window to. It's an extremely common problem on these trucks...
Old Dec 30, 2011 | 01:20 AM
IndyDurango's Avatar
IndyDurango
Here is a good source for fixing the window: http://www.windowmotor.com/
As for the front, "front" in terms of the drivers door? Check the switches first by 'smacking" them to see if they are worn and dirty.
HTH,
IndyDurango
Old Dec 30, 2011 | 07:45 AM
TurboStixx's Avatar
TurboStixx
Hey indy, the front is the passenger door, tried that unfortunately :-( I actually really beat the daylights out of it to see if it helped, no luck :-( Looked at it last night when I was putting the speaker in, connections all look clean and new. I will def check out that website. Thanks Indy
TFYH,
Turbo
Old Dec 30, 2011 | 12:59 PM
adukart's Avatar
adukart
My rear window use to stop about 2in from the bottom. I tore the door apart when i ran new speak wire and ever since then it has been flawless. Don't know what I moved that unjammed it.
Old Dec 30, 2011 | 01:02 PM
TurboStixx's Avatar
TurboStixx
Yeah the funniest thing happened today, I was trying to roll down my drivers side front window so I could get some air in the D, and I wasn't looking, it wouldn't go down so I kept jiggling it...Realized I was pressing the passenger window button when the passenger front window decided to start rolling up and down..I don't know what happened, but hey as long as it goes down then goes back up I am happy, now to change the rear regulator
