Fixed a few things and thought I'd share some pics
Old Jan 27, 2012 | 10:32 PM
that_guy's Avatar
that_guy
Originally Posted by MoparMan1991
Well sure you can. They have units on eBay that have clear style main light housings and you can just re attach the corner lights.
I know that you can because that's what I did (although I did get clear corner lights before that). What I said was that you can't just get the clear piece fluted of plastic that the headlight beam shines through, you have to get the whole headlight housing like this one, not the corners too
Old Jan 27, 2012 | 10:40 PM
MoparMan1991's Avatar
MoparMan1991
Oh I see, That's what i figured you meant after I posted.
Old Jan 28, 2012 | 10:21 AM
Augie Dog's Avatar
Augie Dog
I watched the video and I have a question. Did he put a projector bulb into the housing? I would like to get more light coverage from my HL's. Are there any "how to" videos on You Tube that show how to make upgrades. Also if your lens is hazy making the lights dim wouldn't it be a good time to buff it out while you have it disassembled?
Old Jan 28, 2012 | 10:59 AM
that_guy's Avatar
that_guy
Yes in fact that same guy made this video of how to do the retro fit. projector retrofit Yes, it would be a good time to clean up hazy lenses, but the haze is usually on the outside and it could be too "deep" into the plastic to fix (depending on their age). Mine were too far along to repair so I just replaced them.
I took this picture after I had replaced one of the lenses. You can see how bad the other one looked compared to the new one and the clear corner lenses
Also you CANNOT safely install projectors into the oem housing using the oem fluted lens, you will have to use parts from an aftermarket housing that have the crystal clear lens, like these ones. The fluted lens will distort the light from the projector, cause glare, and is highly illegal to do.
Last edited by that_guy; Jan 28, 2012 at 11:13 AM. Reason: hit the wrong button too soon
Old Jan 28, 2012 | 01:51 PM
adukart's Avatar
adukart
Thanks for the suggestions, I was looking at it cause I had to replace the drivers side from a deer collision. As it sits I can't do the one piece units cause the bumper brackets are bent pushing the bumper into my grille.
Old Mar 4, 2012 | 04:56 PM
that_guy's Avatar
that_guy
So I gave up on that stuff I bought on ebay and decided to get the permatex defroster repair kit and give it a try. I ran into a problem with it at first, being that you have to pull the tape off as soon as it gets tacky. If you let it completely dry and then pull off the tape it will all come off. The other thing is you can't wash the window using windex where the repair is. I've been carefully washing the rest of the window and then using a very fine microfiber cloth around the patches, but not over them.
