4.7 rod bolts
Old Jan 17, 2012 | 11:37 AM
Blind Monkey's Avatar
Blind Monkey
Default 4.7 rod bolts
are 4.7 rod bolts suppose to be one time use? I can't find them on O'rielly's website. if they are one time use I suppose I have to buy a set of them and probally cant buy the 2 i need. I pulled the piston out of the hole that had the nut in it to check for piston skirt damage.
Old Jan 17, 2012 | 08:24 PM
greasydriveway's Avatar
greasydriveway
From Haynes: The rod bolts on 3.7L and 4.7L engines are a torque-to-yeild design and must be replaced whenever they are loosened or removed.
Old Jan 20, 2012 | 11:28 AM
Blind Monkey
dang. can't seem to find them around here as singles. I only need 2 for the one piston I pulled out. check with a few more machine shops to see if they have 2 I can buy.
Old Jan 20, 2012 | 10:33 PM
hydrashocker's Avatar
hydrashocker
Also try www.rockauto.com
