p0420 code...sounds like $$$$$$
Old Jan 18, 2012 | 11:50 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would replace both upsteam and downsteam o2 sensors before replacing the cat. If you need the mopar part numbers, send me a pm with the last 9 of the vin. And I also have a PDF file that the dealer uses for the P0645 code. Page 1 of 2
Symptom:
P0645-A/C CLUTCH RELAY CIRCUIT
When Monitored and Set Condition:
When Monitored: With the ignition key in the run position and battery voltage above 10.4
volts.
Set Condition: An open or shorted condition is detected in the A/C clutch relay control
circuit.
POSSIBLE CAUSES
A/C CLUTCH RLY CIRCUIT WIRING HARNESS OBSERVABLE PROBLEM
A/C CLUTCH RLY CIRCUIT WIRING HARNESS INTERMITTENT PROBLEM
FUSED IGNITION SWITCH OUTPUT CIRCUIT OPEN
A/C CLUTCH RELAY CONTROL CIRCUIT OPEN
A/C CLUTCH RELAY CONTROL CIRCUIT SHORT TO GROUND
A/C CLUTCH RELAY
PCM (A/C CLUTCH RELAY)
TEST ACTION APPLICABILITY
1 Ignition On, Engine Not Running
With the DRB, actuate the A/C Clutch Relay.
Is the A/C Clutch Relay clicking?
AIR CONDITIONING
Yes ® Go To 2
No ® Go To 4
2 Turn ignition off.
Using the schematic as a guide, inspect the Wiring and Connectors.
Were any problems found?
AIR CONDITIONING
Yes ® Repair as necessary.
Perform the Powertrain Verification Test - Ver 2.
No ® Go To 3
3 Ignition On, Engine Not Running.
Wiggle the Wiring Harness from the Relay to the PCM.
Did the wiggling interrupt the clicking?
AIR CONDITIONING
Yes ® Repair as necessary where wiggling caused the clicking to be
interrupted.
No ® Test Complete.
Old Jan 19, 2012 | 02:12 AM
mikeismadness's Avatar
mikeismadness
That last post is gibberish to me to be Honest master tech. The o2s look like the originals to be honest so I was gonna replace both. I was gonna get the densos ill post a link to em to make sure they are the right ones.
Old Jan 19, 2012 | 02:15 AM
mikeismadness
The rear:
http://m.autopartswarehouse.com/sku/....html?loc=Rear
The front:
http://m.autopartswarehouse.com/sku/...html?loc=Front
Old Jan 19, 2012 | 02:35 AM
otgarzà's Avatar
otgarzà
Yeah stick with the densos...when i needed one everyone tried selling me bosch. Ended up going to the dealer and got one for $70. Now i see that they are online
Old Jan 20, 2012 | 11:52 AM
mikeismadness
Ya those are 50-60 a piece
Old Jan 20, 2012 | 12:02 PM
otgarzà's Avatar
otgarzà
Thats a great deal as soon as i was told i had to go to the dealer i knew i was gonna get shafted. Glad youre getting a way better price. Luckily when i bought mine it was all i needed to pass emissions...on the last day of the month.
Old Jan 20, 2012 | 10:35 PM
hydrashocker's Avatar
hydrashocker
You can get them on www.rockauto.com for 1/2 the price of one from the auto parts store. Just got to wait a few days is all. I would only get DESNO or NGT sensors.
Old Jan 21, 2012 | 12:55 AM
otgarzà's Avatar
otgarzà
Awesome find hydra!
Old Jan 21, 2012 | 01:45 PM
hydrashocker
No problem.
Also you can google on the net and find a "rockauto coupon" that will save you the shipping like this: http://www.retailmenot.com/view/rockauto.com
Old Jan 22, 2012 | 09:33 PM
mikeismadness
Thanks hydra! Didn't even think of lookin on rock auto
