Burning Smell coming from Vent area. Need help
Old Jan 24, 2012 | 03:24 PM
kosokustomz's Avatar
kosokustomz
Question Burning Smell coming from Vent area. Need help
So I'm working on a 99 Durango, it has a weird almost like electrical burning smell coming from the vents in side. I could smell it on the outside of the car also.
What do you guys think?
Old Jan 24, 2012 | 09:55 PM
IndyDurango's Avatar
IndyDurango
perhaps the fan is burned up.
Old Jan 24, 2012 | 10:10 PM
that_guy's Avatar
that_guy
yeah, it might be the fan motor
Old Jan 24, 2012 | 10:15 PM
IndyDurango
... and before someone says blower motor resistor... if yours was a 2001, that is exactly where to look. Since it is a 99, yours is outside and under the wiper cowl. There it is doubtful that you would smell it. Plus the style of yours doesn't melt down like the newer ones tend to do.
As such, if it is electrical melt, the likely culprit is the fan.
Old Jan 24, 2012 | 11:30 PM
otgarzā's Avatar
otgarzā
I agree with the fan as well. Since it isnt a foul, old smell then it shouldnt be mold or moisture built up in there.
Old Jan 25, 2012 | 07:12 AM
DomsDodgeDingo's Avatar
DomsDodgeDingo
I had a burning smell to and it was the valve covers leaking oil on the exhaust manifold. I smelled it in the car also
Old Jan 25, 2012 | 11:40 AM
kosokustomz
Its not a oil smell. Its something like the fan motor, however it also has a noise pulley, so I started it up, turned on the heat full, and saw that the A/C compressor was not engaging with A.C on, it was almost like slipping were the clutch was. and after running it for a little bit, the smell was stronger under the hood vs. inside. So I'm about 99.9% the A/C compressor was the smell also.
And when I took off the belt, the pulley on the compressor moved all around lol.
Old Jan 25, 2012 | 12:41 PM
adukart's Avatar
adukart
That is a shot bearing, you need a compressor.
Old Jan 25, 2012 | 12:49 PM
topdogcustoms's Avatar
topdogcustoms
+ 1 adukart
Old Jan 25, 2012 | 03:12 PM
otgarzā's Avatar
otgarzā
Oh yeah...especially if the smell is produced only when the ac is on and its both in the passanger compartment as well as in the engine.
