does my 01 durango have ABS in front tires too? need hub bearing replace, help
Old Feb 2, 2012 | 12:52 PM
Bobman's Avatar
Bobman
Originally Posted by swab
i do not have four wheel drive 4x4, i have rear wheel drive. does that mean i dont have to do the exact steps thats in that video?
Sorry, I assumed that you had 4WD. The RWD should be similar but most likely easier, since there's no front driveshafts to pull out from the hub.
I'd assume that there's an axle nut of some sort that has to be removed, but i don't have firsthand knowledge of the RWD Durango's, sorry!
I think most of the other posts in this thread also assumed that you had 4WD. Perhaps someone with 2WD can jump in here?
Sharps is right on the ABS sensor, just pull the wheel and look for a sensor wire going to the hub. It's quick and painless. You'll also be able to get a firsthand look at the bolts you'll need to remove and see if you have the correct tools before starting.
Bob
Old Feb 2, 2012 | 06:34 PM
pkucan's Avatar
pkucan
Originally Posted by Bobman
...I always use anti-sieze on the bolts when I put these things back together, but that's my preference. Sure makes things easier to get it apart in the future if you need to.
Not sure I would agree with the anti-sieze on those bolts. I believe they come from the factory with the blue type locktite and that is why they are a bear to remove. The locktite prevents the bolts from backing out and losing a wheel. Not that you would lose the wheel but then all you have holding the wheel is the nut on the cv axle and the brake caliper bracket/rotor if memory serves. I would definetly not use the red locktite. Good luck.
Old Feb 2, 2012 | 09:37 PM
swab's Avatar
swab
haha thats funny i was thinking that exact same thing. and the video did say 32mm i dont no why i wrote down 33mm, i just got back from autozone with the 33mm and found out its the wrong size now i got to go back tomorrow and get the right size. however whats weird is with this hub bearing i bought they also gave me a bolt and when i tried fitting the new 33mm socket onto it, it was to small, so i guess i need 34mm for that, im talking about a bolt that came with the new part. so i dont no if the bolt on my car is the same size as this, here is a picture of what im talking about, im not good what parts are called sorry
http://img818.imageshack.us/img818/6209/imagetqr.jpg
and on the box it says "hub assembly" nothing about bearing, i hope its the right part.. here is also a pic of the part, is this the bearing?
http://img803.imageshack.us/img803/6996/imagebr.jpg
http://img39.imageshack.us/img39/6801/imagesug.jpg
Old Feb 2, 2012 | 09:51 PM
mikeismadness's Avatar
mikeismadness
That's what ya need. Looks to be right atleast
Old Feb 2, 2012 | 10:31 PM
swab's Avatar
swab
ya that video im finding out is for 4x4 and not 2wd durango, mine will be completely different i dont have to take the axel out, and i dont have back screws either.
from what someone posted in that videos replies they wrote "for 2wd durango ill need a 36mm socket to get the hub nut off, i guess that is why this 33mm is to small for the hub nut they included with this new bearing, and he also said a 7mm allen wrench to get the breaks off instead of t47
Old Feb 2, 2012 | 10:54 PM
otgarzà's Avatar
otgarzà
Yeah thats the part, bearing is right in the hub assembly.
Old Feb 2, 2012 | 11:25 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
that is the correct part, you cannot (afaik) replace just the bearing you need to buy the whole assembly(like you did)
Old Feb 3, 2012 | 07:24 AM
Bobman's Avatar
Bobman
A good point, but in my experience I've never had a bolt in a highly corrosive area come loose *IF* it's been properly torqued. FWIW, when mine came out they weren't locktited with anything, it was just plain old rust and corrosion. Anti-seize continues to be my friend.
Bob
