Rear differential blues... help
So I drive a 2003 Durango SxT with (i believe) the 4.7L V8 engine and about 125k miles on it.
I was on my way to work driving straight at about 50 mph when my rear differential started to tear itself apart as a result of a missing plug that allowed all the oil to flood out.
I just had the front two top ball joints replaced, had about $1100 in engine work done, and am wonering if this is the begining of the end? Should I dump the money and try and find a replacement rear differential or should I cut my losses and look for a new vehicle?
Cheers!
tl&dr: my rear differential gave out after 125k, replace it or the entire car?
Cheers!
Cheers!
Cheers!
Depends... are you gonna do the work yourself or a shop? This is NOT a known problem with these rigs. A rebuild by a shop ranges from $1200-$1700 depending where it's done. Personally i had my carrier bearings start to "whine" at 160,000 miles, i did the work myself and cost me about $25 for the bearings.. You could also find a nice doner axle at the junkyard and swap it. when i called around here they where going for about $100-$150 bucks.
To me personally i would fix it... but it's kinda a situation here where its to each there own. Good Luck with whatever you decided!
Thanks for the quick replys fellas! Unfortunately I dont have the means to do such work at the place I'm live at, but I have started searching scrap yards for the parts with hopes that a friend with a garrage can put humpty dumpty back together again.
Its tough finding parts like these at affordable rates considering my handicap as a Californian.
The hunt continues.
Cheers!
The hunt continues.
Cheers!
+1 don't want one problem fixed to cause another
