keyless entry
Old Feb 4, 2012 | 08:30 PM
hemi_newman's Avatar
hemi_newman
Default keyless entry
when i bought my 98 durango 5.2 it did not come with a remote can i buy a remote and program it? I see an ad once and awhile on here for them but i want to make sure it will work before i buy it.
Old Feb 4, 2012 | 09:00 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
it depends on if you have the higher end CTM in the truck or not, most trucks are compatible with keyless entry, however without any existing remotes you will need to go to the dealer in order to get the remotes programmed.
Old Feb 5, 2012 | 01:47 AM
that_guy's Avatar
that_guy
if you have of the features in this list that say "high-line only" nest to them you should be able to get a keyless remote programmed
Originally Posted by master tech
CENTRAL TIMER MODULE
DESCRIPTION
Two versions of the Central Timer Module (CTM) are available on this vehicle, a base version and a high-line version. The base version of the CTM is used on base models of the vehicle. The base version of the CTM combines the functions of a chime/buzzer module, an intermittent wipe module, and an ignition lamp time delay relay in a single unit.
The high-line version of the CTM is used on high-line vehicles. The high-line CTM provides all of the functions of the base version CTM, but also is used to control and integrate many of the additional electronic functions and features included on the high-line models. The high-line version of the CTM contains a central processing unit and interfaces with other modules in the vehicle on the Chrysler Collision Detection (CCD) data bus network.
The CCD data bus network allows the sharing of sensor information. This helps to reduce wire harness complexity, reduce internal controller hardware, and reduce component sensor current loads. At the same time, this system provides increased reliability, enhanced diagnostics, and allows the addition of many new feature capabilities.
Both versions of the CTM are mounted under the passenger side end of the instrument panel, outboard of the instrument panel glove box opening. For diagnosis of the base version of the CTM, refer to Central Timer Module in the Diagnosis and Testing section of Chime/Buzzer Warning Systems. For diagnosis of the high-line version of the CTM or the CCD data bus, the use of a DRB scan tool and the proper Diagnostic Procedures manual are recommended. The CTM cannot be repaired and, if faulty or damaged, it must be replaced.
OPERATION
Some of the functions and features that the CTM supports or controls include:
Chimes for the following conditions:
Headlamps on with ignition off and driver door open warning
Key in ignition with ignition off and driver door open warning
ABS lamp warning (if the vehicle is so equipped)
Airbag lamp warning
Check gauges lamp warning
Door ajar lamp warning
Low fuel lamp warning
Low washer fluid lamp warning
Seat belt reminder lamp warning
Transmission oil temperature lamp warning (automatic transmission)
Courtesy lamp defeat
Courtesy lamp time-out (high-line only)
Intermittent wipe control
Enhanced accident response (high-line only)
Horn chirp upon door lock with RKE (customer programmable) (high-line only)
Illuminated entry (high-line only)
Power door lock control (high-line only)
Power lock inhibit (high-line only)
Remote Keyless Entry (RKE) (high-line only)
Remote radio switches (high-line only)
Rolling door locks (customer programmable) (high-line only)
Speed sensitive intermittent wipe (high-line only)
Vehicle Theft Security System (VTSS) (high-line only) (if the vehicle is so equipped)
Wipe after wash (high-line only)
More information on the operation of these CTM features and functions can be found in the group that covers the system to which that feature or function applies.
You may be able to find a ctm from a wrecked durango.
Old Feb 5, 2012 | 03:04 PM
Old_School's Avatar
Old_School
Don't buy a FOB from Ikeyless that has there ad's pop up here, the FOB they say is for the '98 DOES NOT work. You would make more progress sending them $30 and telling them to keep the change..
To the best of my knowledge the only Fobs that work with 98-99's are the Ram Head FOBS.. They can be found all over e-bay ranging from $15-$30 bucks but, as sharps said if you don't have one already, you must visit a dealer or a locksmith to get a program done. The dealer wanted $30-$50 for this, and the locksmith did mine for $20...
Also, check your build sheet, if it says "keyless entry" your golden... they you can buy FOBS and program them... If you don't have a build sheet you can email dodge and give them your VIN and they will email you a build sheet.... you can request one here -->http://www.dodge.com/wccsapp/univers...ull&category=R
HTH,
Jeremy
Old Feb 5, 2012 | 04:00 PM
that_guy's Avatar
that_guy
+1 on ebay and the rams head
Old Feb 5, 2012 | 04:26 PM
hemi_newman
i looked and i do not have a build sheet so i might have to send in for one.
Old Feb 5, 2012 | 04:28 PM
hemi_newman
i looked on ebay and only can find ones with the chrsylier star not the rams head
Old Feb 5, 2012 | 08:32 PM
that_guy's Avatar
that_guy
what are you typing in? I just typed in "durango fob" and tons of them came up
Old Feb 6, 2012 | 08:45 AM
hemi_newman
1998 dodge durango keyless remote..is what i typed in.
Old Feb 6, 2012 | 12:30 PM
topdogcustoms's Avatar
topdogcustoms
Here you go
http://www.ebay.com/itm/OEM-DURANGO-...#ht_2179wt_690
