rear end clattering while turning in reverse
Old Feb 10, 2012 | 08:26 PM
Nicholas Frenier's Avatar
Nicholas Frenier
Question rear end clattering while turning in reverse
02 durango slt plus awd 360 v8. while in reverse and making a sharp turn theres a clattering coming from the rear end? maybe shoes cause it does it while im on the brakes, hoping its not the rear seeing as how i just bought it and the dealer i just bought it from wont cover anything now ****, any ideas?
Old Feb 10, 2012 | 10:10 PM
Nicholas Frenier
checked the diff fluid its clean as a whistle im assuming its the brakes im gonna add a friction modifer in the morning too make sure its not the rear, antislip diff means limited slip correct?
Old Feb 10, 2012 | 10:51 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
correct, i am leaning towards a bad LSD since it sounds like you are describing what my dads truck was doing about 3k miles after he bought it, at 37k miles (just out of warranty) they ended up rebuilding the rear end for him (bc he had been complaining about it for so long)
his would chatter when making right hand turns, and would not lock up properly under normal driving (snow) when it should.
Old Feb 11, 2012 | 03:05 AM
crawlin95's Avatar
crawlin95
yup clutches in lsd bad
Old Feb 11, 2012 | 10:52 AM
Nicholas Frenier
it could be but theres not metal shavings in the fluid? im gonna add friction modifier to it to see what happens i hope its not the rear im hoping its the brakes or something small
Old Feb 11, 2012 | 11:56 AM
shrpshtr325
THE ULTI-MOD
there probably wouldnt be metal shaving if the clutches are worn out, maybe some clutch material, but idk if you would even notice that in it,
also the brakes would NOT qualify as something small, least not IMO, and they also pose a saftey issue if they arent working right.
Old Feb 11, 2012 | 12:46 PM
Old_School's Avatar
Old_School
This is in no way intended as a final fix, i would still have the clutch packs looked at to confirm if there good or not but, you could try swapping the current fluid with 80-140 as see if she quiets down a bit.
Personally, i started to have a "whine" in my rear diff a few months ago... while i did change the carrier and pinion bearing (they where ready to be replaced) i still had a bit of gear noise... once i put in the heavier weight gear oil she quieted down.
Like i said tho, i would still have the clutches checked out to make sure there ok even if the heavier weight gear oil does quiet her... better safe then sorry!
Old Feb 11, 2012 | 01:43 PM
Nicholas Frenier
put the friction modifier in it hasnt done it since, maybe im lucky
Old Feb 11, 2012 | 01:46 PM
shrpshtr325
THE ULTI-MOD
you might be lucky, for your sake i hope you are, and that you have not done any significant damage to the system by running without the modifier
Old Feb 11, 2012 | 02:06 PM
Nicholas Frenier
yeah i didnt know it was a lsd till i looked in the glove box, i bought it and didnt know what the rear was till last night, its only done it a couple of times so i dont think i broke anything if i did ill keep you guys posted thanks for all the help
