Odd Vibration while accelerating
Old Feb 12, 2012 | 04:26 PM
mvorpahl's Avatar
mvorpahl
Default Odd Vibration while accelerating
OK, so i have a 99 durango 5.2. while driving between 50 & 60 mph i have a slight vibration when i accelerate slowly. this only happens when the od is on. if i turn the overdrive off this don't happen. when the cruise is on and it calls for more power to go up a small incline it vibrates slightly like the tranny is slipping but there is not any jerking when this happens. and when accelerating a little more aggresively, the vibration is not there. only when accelerating slow and gradually. anyone? i took it to a mechanic but it is a ford dealership that has two garages, one for fords and the other one that does repairs on other makes and models. they say that they couldn't find anything wrong via code or anything that it must be internal. just wondering if anyone else has had this problem and can help?
Old Feb 13, 2012 | 06:37 PM
hydrashocker's Avatar
hydrashocker
Could be a bad U-joint on the rear main drive shaft.
Old Apr 19, 2012 | 10:06 PM
k2durando's Avatar
k2durando
Default Same problem
I have the same problem with my 00 5.9 durango. I connot figure out what is causing it. I hae already replaced the U joints and still there.
Old Apr 19, 2012 | 11:50 PM
jmess's Avatar
jmess
i had it happen for a little while. i assumed it was maybe my driveshaft off balance but it eventually went away
Old Apr 20, 2012 | 12:35 AM
mikeismadness's Avatar
mikeismadness
Bad tire or tie rod maybe?
