my blinkers wont blink
Old Feb 16, 2012 | 12:56 AM
topgunram's Avatar
topgunram
Default my blinkers wont blink
i know, i know do my research. but sometimes this is quicker and easier. like the title says. myblinkers dont like blinking all the time. i know it should be an easy enough fix but iv never had to deal with this before. so a little advice wont go amiss. what do i need to do to fix it and where is it located on the vehicle. 2000 dodge durango slt plus with the 5.9 and awd. thanks again.
Old Feb 16, 2012 | 01:20 AM
jmess's Avatar
jmess
Have you checked fuses, grounds, and connections? Is it all 4 that won't work? Do they light up on the dash? If so do they blink normally or faster?
Old Feb 16, 2012 | 02:25 AM
otgarzā's Avatar
otgarzā
If they blink a few times and shut off after a few seconds but the multifunction switch is still in the up or down position it may be the flasher.
Old Feb 16, 2012 | 09:21 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would say it is probably the multi-flasher, not sure where it is on the 2000s tho, if it is both sides that do it then the multi-function stalk may be the problem (highbeam/turn signal switch)
Old Feb 16, 2012 | 12:15 PM
Old_School's Avatar
Old_School
98-00 its the green square thing in the fuse panel by the drivers door.
Old Feb 16, 2012 | 12:24 PM
otgarzā's Avatar
otgarzā
+1. Should solve the prob
Old Feb 16, 2012 | 02:33 PM
topgunram's Avatar
topgunram
good to know. sometimes they work sometimes they blink a couple times and go solid. im thinking its the flasher. ill order one tomorrow
Old Feb 18, 2012 | 01:58 AM
otgarzā's Avatar
otgarzā
Let us know if it fixes the problem
