2002 Durango Brake Light Question
Old Feb 16, 2012 | 02:43 PM
mariavsand's Avatar
mariavsand
Post 2002 Durango Brake Light Question
Here's the problem: My left brake light does not function, turn on when brake pedal is depressed, unless I have turned on my headlamps. I have checked my fuses and they are good and I have changed the bulb. The other two brake lights work normally. Does anyone know if the brake switch on the brake pedal have individual wires going to each side of the vehicle? If it doesn't, could the most likely cause be the splice that connects it to the right side be the culprit? Any help would be appreciated.
-Maria
Old Feb 16, 2012 | 05:38 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
ill move this to the 1st gen section for you but it sounds to me like a loose connection or ground
Old Feb 18, 2012 | 12:41 AM
hydrashocker's Avatar
hydrashocker
No the brake switch is separate. It switches into separate lights in the CTM, however I think the third brake light is illuminated by the switch..
Check the bulb or the bulb harness.
