programming new fob...
Old Feb 17, 2012 | 11:32 PM
KimberlyAnn7911's Avatar
KimberlyAnn7911
Wink programming new fob...
I only have one working keyless entry thing-a-ma-jig for my durango as thats what was given to me when I bought it, however I would really like to have two. I dont know if I need to order one through dodge/chrystler or wether I can find one at a parts store/junkyard or if the one from my other dodge(not durango) will work for this. I know that it will have to be programmed but at one point someone on here actually had the procedure, which would be great to see again, anyway I guess my question is...what is the actual process for something like this?
Old Feb 18, 2012 | 09:58 AM
that_guy's Avatar
that_guy
it'll depend on the remote that was used for the other dodge, but usually if the remote looks the same (isn't the square one) and has the ram's head on it, it can be programmed to a 98-00 durango. You can also find the remotes on ebay if you really wanted another one.
Here are the programming steps:
Originally Posted by Old_School
1. Press LOCK button 5 times at 2 second intervals to resynchronize remote.
2. Insert key into the ignition switch. Turn ignition to the RUN position (as far as you can
go without cranking engine). Wait for ignition chimes to stop.
3. Using the working remote, press and hold the UNLOCK button on the remote for 4 to 10
seconds.
4. Within the specified 4 to 10 seconds, continue pressing the UNLOCK button and then
press the PANIC button ( on the programmed remote ) for 1 second and release both
buttons. A chime will sound to indicate that the remote programming mode has been
entered ( allow 3 seconds for chime to sound ).
5. Within 30 seconds of the chime, press and release the LOCK and UNLOCK buttons
simultaneously then press and release just the UNLOCK button on the same remote.
A chime will sound indicating the remote has been programmed. Press and release
the LOCK and UNLOCK buttons simultaneously and then press the UNLOCK button on
each new remote you wish to program at this time. Locks will cylce afer each additional
remote is programmed.
6. Turn the ignition OFF and remove key.
7. Test Remotes.
Here's a link to a remote on ebay that would work if you wanted another one. They seem to be going for around $20.
Old Feb 18, 2012 | 10:45 AM
Old_School's Avatar
Old_School
Here's a link i found two for $25 bucks!
http://www.ebay.com/itm/2-NEW-KEYLES...10226380450079
Since you have one working remote you should be able to use the steps above to program them yourself..
Old Feb 18, 2012 | 11:26 AM
that_guy's Avatar
that_guy
even better
EDIT: Actually I don't think those ones will work. They don't have the rams head and it says 01-03 durango.
Old Feb 18, 2012 | 12:35 PM
Old_School's Avatar
Old_School
Originally Posted by that_guy
even better
Yes they will those are the ones i bought and programed on mine. As long as there the same shape as the rams head ones they will work
Old Feb 18, 2012 | 02:09 PM
that_guy's Avatar
that_guy
Not necessarily. I have one that's the same shape but doesn't have the ram's head and it won't program to my car. It programmed to my friends dakota so it does work. The 98-00 trucks use the ram's head ones and the 01-03 use the ones without it. Here's a thread where this has been discussed. I'm not sure why that one works for your 98.
Old Feb 18, 2012 | 05:18 PM
KimberlyAnn7911
Thanks guys! Ive got a keyless entry from my '99 Ram, will see right now if it can be programmed. The one that I got with the Durango though...was the square on with the chrystler sign on it, do they have to be the same in order to work?
Old Feb 18, 2012 | 05:24 PM
Old_School's Avatar
Old_School
the square ones will NOT work
Old Feb 18, 2012 | 06:25 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
it sounds to me like they have the square one for it already working.
i did not think the square ones worked either, however if i already had it i would definitely try it, i cannot tell you for sure if it will work, but you have nothing to loose except for a few minutes of your time.
Old Feb 18, 2012 | 09:41 PM
KimberlyAnn7911
Yes, we have one square on that we got with the durango and another from a different dodge. Now since both of them are square and one(1) is already programmed to work for the durango.....will the other one be compatable or do I need to buy one with the ram head on it? Thanks again
