No oil on the dipstick but good oil pressure
Hey guys I checked the forum and google and haven't really been able to find what I'm looking for. I have a 1999 dodge durango 5.8l 4x4. About a month ago I checked my oil and everything was A-O-K. Today my wife was dropped it off for an oil change and they called her after a while and said there was no oil on the stick. We don't have any oil in our driveway or anywhere we park and the oil pressure was always between the 40 and the next line on the pressure gauge. I'm wondering if you can have oil pressure and still have no oil on the stick or if they maybe messed somethign up and are trying to cover their butts. I guess the larger problem is finding out how my D and run out of oil and leave no traces.
Here is a thread that explain how to do it...
https://dodgeforum.com/forum/1st-gen...ml#post2678319
and here is the replacement kit for it....
http://www.hughesengines.com/Index/p...z&partid=26190
hope that helps...
old school
also check your dipstick, one member on here had a problem with his oil level reading with the manual specified amount of oil in the truck, turns out the previous owner had replaced the dipstick with the wrong one.
if you give us your engine size someone on will probably be willing to measure theirs for you as a comparison.
Although - on occasion, I've seen them only really smoke if you put a good load on the engine, probably pushing oil into the cylinders when the pressure comes up. So if you have a second car or someone to ride with you and watch out the back, give it some gas up a decent hill and see if it starts smoking. Usually oil smoke will be more of a bluish color, coolant is white.
The only other time I know of that to happen... ehh, maybe, is if perhaps the rear main seal on the engine is leaking oil into the transmission's bell housing or something. I've never torn the Durango down that far to see what's in the back of the engine there, that's just a guess.
And yet one other possibility - a blown head gasket/something cracked internally in the engine. But usually your coolant/oil will show signs of mixing. So if there's no water in the oil or oil in the coolant it shouldn't be that.
But no oil on the stick is a major 'OMG' moment - get it up to level ASAP, if you need to - park over a clean piece of cardboard and it might help show if you do in fact have a leak. Of course, if your driveway's clean, that should be good enough - I can't say that much myself... lol
Oil loss with no noticeable leak - always concerns me a lot, personally. I mean it *has* to be going somewhere...
But in the off chance that power steering fluid preserves concrete, mine will be there for a very long time....
