Please Help
Old Feb 22, 2012 | 06:55 PM
littlelady's Avatar
littlelady
I found another heater control for $30. Any Ideas on how to change them?
Old Feb 22, 2012 | 11:03 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you need to slide the dash panel out iirc, its the same as getting to the radio.
Old Feb 23, 2012 | 05:25 PM
littlelady's Avatar
littlelady
Thank you. It should be here next week.
Old Mar 28, 2012 | 02:09 PM
littlelady's Avatar
littlelady
I changed the heater control head. The rear defrost light is still blinking. I have AC, but no rear defrost. The light for the AC doesn't come on either. Any other ideas as to what is wrong?
Old Mar 28, 2012 | 07:21 PM
Old_School's Avatar
Old_School
Start pulling fuses in the PDC under the hood and in the fuse panel at the drivers door... there almost has to be a blown fuse somewhere if the A/C light will not come on unless its a bad bulb....
Old Mar 28, 2012 | 07:57 PM
hydrashocker's Avatar
hydrashocker
You can try to test for power at the switch then after the switch. If everything looks good it would have to be further down line.
Old Mar 29, 2012 | 03:48 PM
littlelady's Avatar
littlelady
Thank you. I will start checking fuses and then the power thing this weekend.
