P0420 1/1 Catalytic Conv Eff
Old Feb 24, 2012 | 02:39 PM
spork40's Avatar
spork40
Default P0420 1/1 Catalytic Conv Eff
in a durango what typically causes this code? P0420 1/1 Catalytic Conv Eff
o2 sensor? cat? plugs/wires?
Old Feb 24, 2012 | 02:41 PM
mikeismadness's Avatar
mikeismadness
How along was your last tune up? Mine threw that code, I did a tune up cleaned the throttle body intake and ran some Lucas fuel cleaner and icleared the code and never came back. Change the o2 sensors, that could be the cause if not its the cat converter
Old Feb 24, 2012 | 02:51 PM
spork40's Avatar
spork40
did you change plugs, wires, distributor, etc?
Old Feb 24, 2012 | 03:03 PM
TurboStixx's Avatar
TurboStixx
o2 sensor POSSIBLY, but in my experience, I changed the o2 sensors, and the cat was bad/clogged.
Old Feb 24, 2012 | 04:05 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
post cat O2 sensor, or bad cat.
however if you clear the code and it stays away i wouldnt be too concerned about it. so try that and a tune up first.
Old Feb 25, 2012 | 09:00 PM
spork40's Avatar
spork40
is there a way to know which o2 sensor it could be? right or left? up stream or down stream?
Old Feb 25, 2012 | 09:38 PM
TurboStixx's Avatar
TurboStixx
Change both Downstreams if you aren't getting any codes
Old Feb 25, 2012 | 09:51 PM
shrpshtr325
THE ULTI-MOD
to my knowledge the 5.9 only came with 2 O2 sensors, one pre cat sensor and one post cat sensor, change the post cat sensor, (the one AFTER the cat, farthest away from the engine)
