Did brake lines every change?
Old Feb 24, 2012 | 04:17 PM
RollerRed's Avatar
RollerRed
Default Did brake lines every change?
I am looking to get new brake lines and was wondering if there was a big difference between 00 and 98 brake lines? Like did they change or is there a different connector piece etc.
Old Feb 25, 2012 | 11:02 AM
RollerRed's Avatar
RollerRed
No one?
Old Feb 25, 2012 | 11:31 AM
topdogcustoms's Avatar
topdogcustoms
the 98 is 9.5" long and the 2000 is 11.625" long other then the length there the same
Old Feb 25, 2012 | 06:27 PM
RollerRed's Avatar
RollerRed
Well that shouldn't be to much of a problem I dont think.
Old Feb 25, 2012 | 09:47 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
are you referring to the hard lines or the soft lines?
since the banjo bolt at the caliper changed somewhere along the line the connection to the caliper through the banjo bolt also had to change, im not sure when this change happened (this is a change in the soft lines, not sure about the hard lines)
Old Feb 25, 2012 | 10:07 PM
topdogcustoms
this is for a 98
Part Number:
78702
Weight:
0.7 lbs
Warranty:
3 MO
Notes:
Driver sideMay require hose lock replacement, part number H1457A
Bracket Material:
Stamped Steel
Brake Hose Assembly Length (In):
9.5
Brake Hose Assembly Segment 2 Length (In):
9.25
End 1 Fitting Material:
Treated Steel
End 1 Type/Size of Fitting:
Banjo - 10 mm
End 2 Fitting Material:
Treated Steel
End 2 Type/Size of Fitting:
Female - M10 x 1.0
Gaskets Included:
Yes
Hose Material:
EPDM Rubber
Installation Hardware Included:
No
Driver Front
Package Contents:
Brake Hose, Gaskets
Shipping Information:
Overnight and Two Day shipping are not available for PO Box, APO/FPO/DPO or US Territory addresses.
and a 2000
Part Number:
70802
Weight:
0.7 lbs
Warranty:
3 MO
Notes:
Bracket Material:
No Bracket Required
11.625
12.625
Treated Steel
Banjo - 10 mm
Treated Steel
Female - M10 x 1.0
Gaskets Included:
Yes
Hose Material:
EPDM Rubber
No
Driver Front
Package Contents:
Brake Hose, Gaskets
Old Feb 26, 2012 | 12:37 PM
RollerRed's Avatar
RollerRed
Just the soft lines. I checked the hard line and it looks newer and nothing is wrong there. But I need to change the soft lines out. I guess there are only three lines. I was just going to go SS and call it good.
Which is why I asked because they only make them for 2000-2003. I emailed the company and they said they would be alittle longer but would work. So I wanted to double check on here.
