3in body lift.. questions.
Old Feb 25, 2012 | 11:16 PM
lbzrango's Avatar
lbzrango
Default 3in body lift.. questions.
So i just did my t/s lift about a month ago and im wanting a little bit more height before spring and summer hit. so i think that my best bet is to go with the PA 3in body lift with some 33's.
I have done alot of reading on the lifts and understand the main problem is the steering extension.
What problems did you guys run into while doing this? and what did you do to fix/solve the problem?
Will i need the extend my front brake lines?
And is there anything i should be concerned about?
Thanks in advanced!
P.S i will take allot of pictures and make a write up about how to do the body lift as soon as im done. because i havn't found a decent one yet.
Old Feb 25, 2012 | 11:27 PM
adukart's Avatar
adukart
Check this out https://dodgeforum.com/forum/1st-gen...body-lift.html
I'm sure jmess and duranged408 can answer all your problems can answer all of your questions.
Old Feb 25, 2012 | 11:33 PM
lbzrango's Avatar
lbzrango
Wow thanks alot haha, iv been searching and searching for a decent one.. this one awnserd alot.
