2000 durango error code p0340
Old Mar 6, 2012 | 03:35 PM
Gene Crain's Avatar
Gene Crain
Default 2000 durango error code p0340
I have changed both the cam & crank sensors "wow what a bitch" and it still wont start. how do I clear codes and any ideas on what might be wrong. I am not a car guy so use simple terms please
Old Mar 6, 2012 | 04:25 PM
samnbensdad's Avatar
samnbensdad
Disconnect the negative battery cable, turn the key to the start position and hold it for 30 seconds. Reconnect the battery. Start it, let it idle for 10 seconds without touching the accelerator. Kill it, then drive as usual.
Old Mar 6, 2012 | 05:35 PM
Gene Crain's Avatar
Gene Crain
I tried that I got the codes to clear but it still won't start it's not giving me any more codes
I checked the connections to the sensors and they are clean and pluged in.
I will try dissconnecting the battery again and start from scratch. Might have a cheap Durango for sale lol
Old Mar 6, 2012 | 06:40 PM
samnbensdad
Have you checked the pressure at the fuel rail?
Old Mar 6, 2012 | 07:24 PM
Ketill's Avatar
Ketill
Ignition on,it should be 5v in to cam sensor and crank sensor from pcm , the wire out from cam sensor to pcm should be fom 0v to 5v. when cranking, test with analog meter.
Do you have 12v at the orange/green wire on coil when cranking ? If you have, then the crank sensor is good I think.
On my car I measure 5v fom pcm to cam sensor, and 4,2v on the wire who goes back to pcm.
My promlem is the pcm is generating both of the voltages, and my car will not start.
I got 12v to coil but I could not get the right signal to ground on coil.
I have also changed crank sensor.
Old Mar 7, 2012 | 01:50 PM
Gene Crain's Avatar
Gene Crain
Default new error code p0123
Well it almost started but is now flashing code p 0 1 2 3
off to find out what that is. please reply if you know
Last edited by Gene Crain; Mar 7, 2012 at 01:54 PM. Reason: erro code coming up as missing pic
Old Mar 7, 2012 | 05:25 PM
samnbensdad
TPS (throttle position sensor)
