Vacuum line, where does it go?
Old Mar 6, 2012 | 08:26 PM
NW Redneck's Avatar
NW Redneck
Default Vacuum line, where does it go?
Hey guys, I was just doing some maint on my 2001 5.9l R/T and heard a hissing noise while it was idling. I found that a mouse had got in there and chewed off a hose on the passenger side of the intake manifold and I can't find a hose dangling anywhere that should go there! If I block the port the engine idles down and dies so it's got to go somewhere. Where? Pics below.
Thanks!
Old Mar 6, 2012 | 11:21 PM
IndyDurango's Avatar
IndyDurango
That side port should just be capped off IIRC.
IndyDurango
Old Mar 7, 2012 | 12:25 AM
NW Redneck's Avatar
NW Redneck
If I plug that port the engine dies in about 3 seconds.
Old Mar 7, 2012 | 10:11 AM
samnbensdad's Avatar
samnbensdad
Mine is capped.
Old Mar 7, 2012 | 11:35 AM
jmess's Avatar
jmess
Mine is also capped.
Old Mar 7, 2012 | 12:56 PM
TurboStixx's Avatar
TurboStixx
Mine is capped as well, but my PCV Valve attaches just above that one on my truck
I'll get ya a pic next time I go outside.
Old Mar 9, 2012 | 08:35 PM
NW Redneck's Avatar
NW Redneck
Thanks for the replies guys! I found that if I blocked it off with my finger quickly the engine would just die. If I blocked it slowly it would idle down a little than be fine. If I started it with it blocked no problems. Port is now capped. Thanks again!
Old Mar 14, 2012 | 01:29 AM
IndyDurango
Great! I was pretty sure that was it.
Damn mouse!
IndyD
Old Mar 14, 2012 | 11:25 PM
hydrashocker's Avatar
hydrashocker
Yep, it is capped off.
Turbo, yours is a 1999 which is a different set up then the 2000-2003. They switched sides on everything.
