electrical problems help!
ok so here we go i have 99 d with a 5.2 mag lately the truck will just shut down by itself then wont crank when i turn on the key the guage says no bus and the gauges wont show the batter fuel or heat and the auto shut off relay is going haywire clicking like hell if i pull it out and put it back in it stops but wont crank
then if i lift up the fuse box it will crank so i thaught it was a loose wire so i took the fuse box apart and checked everything and nothing all wires tight and clean no burnt and the ground by the box is tight and clean
what could it be?
what could it be?
