Leaf Spring Question
Old Mar 25, 2012 | 07:58 PM
TurboStixx's Avatar
TurboStixx
Default Leaf Spring Question
Alright guys, so I have figured out my springs are worn and sagging. At 171k miles, it is possible. I have gotten the ability to pick up a set of springs off of a wrecked 99 for $50 for the set. However, the gentleman I spoke with believes the springs were over axle mounted. I have under axle. What if anything do I need to change to make this swap? Do I need to weld new perches to the axle to make this work? This buy depends on your answers. I have been looking for good springs but didn't want to pay $300 for a set. I have been gathering all the parts to rebuild the suspension in the rear, and these springs are the last thing I need to buy before I start the project. Thanks Guys!
If you need pictures of my rear, let me know, I can post them in minutes.
Old Mar 25, 2012 | 08:14 PM
Duranged408's Avatar
Duranged408
no stock durango was ever spring over unless a lift kit was installed or replaced. Many a few people think the durango is spring over so he may be confused. If it was a kit installed i wouldnt go through the hassle of swapping. When i broke a spring i went with a Dakota +4 spring which matched my TS so stock shackle was used.
Old Mar 25, 2012 | 08:16 PM
TurboStixx's Avatar
TurboStixx
sweet thanks, yeah this guy already sold the rear and didn't sell the springs and he runs a salvage yard and wasn't looking at the truck. I started thinking after I posted and was like wait, if it is the same year..should be the same spring unless lift kit, but no lift kit was installed. Thanks!
Old Mar 25, 2012 | 08:20 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yup as stated all durangos are spring under axle; dakotas are spring over axle
Old Mar 25, 2012 | 10:34 PM
TurboStixx's Avatar
TurboStixx
Thanks guys
Old Mar 25, 2012 | 11:12 PM
adukart's Avatar
adukart
Not trying to thread jack but that is really weird they have the same basic design but the Dak's are SOA.
Old Mar 26, 2012 | 04:57 PM
topdogcustoms's Avatar
topdogcustoms
do you remember where you got the springs from
Old Mar 26, 2012 | 10:27 PM
TurboStixx's Avatar
TurboStixx
Question, I have the springs, they look in good shape, going to wire brush the dust and little surface rust off of them, and paint them with black rust-o-leum and then coat it with acrylic enamel to help the paint last longer.
I am replacing the bushings, and bolts.
My question...There are 2 pieces of metal on the springs about middle between where they connect to the hangers and where it connects to the axle. These are loose and I would like to replace them. But I can not find the name of the part. Could it be Leaf Spring Insulators? Thanks in advance!
Old Mar 26, 2012 | 11:27 PM
TurboStixx's Avatar
TurboStixx
hahahaha, google just answer my question, I got fed up with looking so I left the computer. Came back to check the forum, and then started typing Leaf Spring in google and it said Leaf Spring Clamps? I looked, and viola, that would be them...
Old Mar 27, 2012 | 07:49 PM
hydrashocker's Avatar
hydrashocker
Are you talking about the U-Bolts? Yes you need to replace them.
