O2 sensors on 5,9 rt
Old Apr 2, 2012 | 04:40 AM
Cohm's Avatar
Cohm
Default O2 sensors on 5,9 rt
Where are the O2 sensors located on my durango 2001 5,9 rt
Old Apr 2, 2012 | 11:32 AM
mikeismadness's Avatar
mikeismadness
There is one behind the catalytic converter, and one right off the passenger side manifold. There may be one on the driver side manifold too
Old Apr 2, 2012 | 01:50 PM
Cohm's Avatar
Cohm
Ok thanks which manufakturer should you recommend
Old Apr 2, 2012 | 03:56 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
it depends on your emissions setup, you could have 2 or 4 sensors
if you have ca emisisons you have 2 on each side, one before and one after the pre-cat on each side before the y pipe
if you have non ca emissions you have 2 total, one before the cat and one after it.
denso or mopar brand only for these trucks or else you will have problems.
Old Apr 2, 2012 | 09:22 PM
mikeismadness
Thanks shrp for chiming in, but yes denso or Ngk
Old Apr 3, 2012 | 09:44 AM
Cohm's Avatar
Cohm
Thanks off to buy new ones.
And gaskets for cleaning TB i looked in totally black almost (probably never cleaned)
And PCV just changed.
